I've done car stereo installs before. This is my third one.
Car is a '96 Sentra. Replacing the stock unit with an old Pioneer DEH-P7200.
I hooked up the wiring harness to the Pioneer harness, pretty standard procedure. All wires match up except for the unnecessary ones (illumination, dimmer, power antenna, amp, phone/mute).
I turn the car to ACC, no power, no display, nothing.
I turn the car on, I get dash lights, test blinkers, wipers, etc. All accessories work fine.
Strange... I unplugged the Pioneer and hooked the stock unit back up and still nothing. Not even the time on the cheesy LCD that should come on.
Next thing I checked was the fuse box. The fuse looked fine, but just in case, I swapped it with the spare ones. Still testing with the stock unit and I still get nothing.
I doubt both HU's went bad at the same time. Power is not the issue either.
I must mention that when I did the installation, I did not unplug the negative terminal on the battery.
If that destroyed something, what must be done to fix it?
