Hi all, I'm having a problem installing a sony deck on my '91 Golf GTI. The car came with factory amplifiers, and 6 speakers.
Here are the problems:
1. No power up. I tried connecting just the power cable to see if the deck would power up, but no success. Here is the breakdown:
Factory end - aftermarket deck end
Red power cable - red power cable
Orange power cable (the closest thing I can find to yellow) - yellow power cable (I think this is the memory power cable)
Ground - Ground
What's wrong here?
2. Speaker cable problems. I haven't work this part yet, just trying to figure out how I'm going to connect the speaker cables.
The factory end:
FL positive
FR positive
RR positive
RL positive
1 common ground cable
The aftermarket end:
FL +
FL -
FR +
FR -
RR +
RR -
RL +
RL -
How will this work? The guy at crutchfield say I can buy an adapter from them that will solve the common ground issue. However, my friend who is quite knowledgeable said he bought that adapter once, but I don't really need it. He says I can hook one negative from the aftermarket end (either one from the four negatives) to the ground from the factory, and that should do it. I'm skeptic about this.
Second, since the car came with built in amplifiers (active spkrs), the power rating from the aftermarket head unit should be too high. That same crutchfield adapter is also supposed to fix this problem, by lowering power from the head unit. My friend says I don't need it, just connect them directly, the speakers should be able to handle the power. I have no idea what the ratings are from the factory speakers.
Best buy says the only way to solve this speaker problem is rewire everything. Yea, right. $$$$$.
Please help me.
Ground - Ground
What's wrong here?
The factory end:
FL positive
FR positive
RR positive
RL positive
FL +
FL -
FR +
FR -
RR +
RR -
RL +
RL -
Please help me.
