Car stalls out sometimes......What exactly does a tune-up do?
JesusCow
569
hmm, ive had the same probs with my 91 mazda mpv, but i fixed it myself! just a 45 dollar part, it was something with the wiring to this little tube thingy (not to good with cars) but before i got it fixed, i had to put in park if i stopped (red light, stop sign...). if it;s under warranty, take it to dealer and have the check it out, if not, a gas station may know what's up with it. good luck!
isekii
28,578
Get a new car ?? :)
hehe perfect solution
Acura Legend is a nice a$$ car tho..
I Love the 2 doors..
pulpp
2,137
could be dirty fuel injectors, get some fo those fuel system/injectors cleaners and put it in before filling the tank and see if it helps, or take it for a tune up.
geno
25,074
4
Random stalling could be caused by tons of things:
bad ignition system
incorrect timing
dirty fuel system
dying fuel pump
bad speed sensor (dunno how the Hondas are set up around this though)
those are some of the basics - you're best off taking it to a mechanic you can trust and have them look through it.
geno
25,074
4
<< Have the muffler bearings replaced >>
That - and don't forget to flush your blinker fluid :)
Fandu
Check your radiator oil level :)
Serisouly, sounds like maybe injectors or a dying O2 sensor.
etech
I don't have a Honda, but I'll throw mass air flow sensor into the possibilites also. Sometimes they get dirty and stick throwing the computer off.
Check the relative bearings also. <-- old Navy joke.
