Car searching, info inside with link!
Steering was very light, normal?
What do you mean?
If it's 5 years old and has a depreciate rate of 10% per year, it should currently be 59% of its original price, which would put it at $17,000 new.
At 20% depreciation per year, it would be 33% original price, which means new price would be about $30,000
When my Honda Civic was destroyed and I was dealing with the blue book value, the write off value given worked out to be roughly 10% depreciation per year, and that's for a car that's known to have a remarkably low depreciation rate. If the G6 is somewhere around 15-20% per year, then this price sounds accurate for what the car is actually worth. The only fishy thing is why nobody else has bought it in the past 3 years.
Yeah understandable
Now looking into a sentra 2008 with 15k miles for 12000.
If you can tell; we're looking for four door sedans/compacts
Any opinions on a 2008 Nissan sentra 2.0 S
He wants 12,000 for it; original owner, always serviced at the dealer. CVT transmission; still under warranty.
I did a search for "2008 sentra sucks" and a recurring result relates to weird tire wear on the back tires.
http://www.nissanforums.com/b16-2007/148753-2007-sentra-2008-sentra-rear-alignment.html
Post 1:
Problem - The Sentras commonly do not meet Nissan Specs for rear alignment. Many are off about 1.2 degrees or about 3/8 inches for Toe In.
Symptom - excessive rear tire wear demonstrated by diagonal wear lines and load tire noise. Effectively hidden during the warranty period by rotating the tires. Refer to Honda Service Bulletin 08-001 for a good explanation and pictures. Honda has a similar problem that they owned up to and are correcting. What does that say about Nissan?
Post 2:
I had an identical experience with my 2007 Sentra. After months of haggling through all of the Nissan mazes, they offered me $2,000 and two new tires to go away. I took it, and instead of going away, I went to a wheel alignment specialist, and for $325, he corrected the problem. It sounds like I made out pretty good, especially since my gas mileage went up from 34 to 38 on the highway.
Post 3:
I am so glad I just found this forum! My 2008 Sentra was just in an accident due to slippery conditions on my worn tires. I have attempted to rotate the tires as scheduled and checked them again before winter. I could not believe that the rears always looked worse than the front. I also could not believe all four were getting pretty bad and the car isn't one year old yet.
Post 4:
I just updated the other thread about this. I got a resolution from Nissan, they only paid for two new tires, but I got something at least, check here <link>
Post 5:
I'm not sure if this is the right place to post this, but I have a 2007 Sentra 2.0S and have symptoms consistent with rear alignment problem described in this thread.
(update) :
Rear alignment update: I took my 07 Sentra to a well recommended alignment shop to perform a front and rear alignment. They found that the rear alignment was off, specifically the toe-in (as suspected). They installed shims to to fix the problem, only cost $35 more on top of the regular $100 for the alignment. Will update in a few months if rear tire wear and fuel economy have improved.
Post 6:
I've had a very similar experience, got my '07 in '08 with 16k miles, thought I got a great deal, now I realize I got a pile of crap. Within 4k miles the tires that came with the car were shot. Took it to Nissan, they told me it was an alignment problem, not under warranty, and that I had to get a four-wheel alignment every 12k miles! I had a '92 Camry that I bought in '99, put 260k miles on it and only did two alignments ever. That averages to 130k between alignments, and Nissan wants me to spend $100+ every six months or so? Not to mention when I finally got the recall notice for the airbags, they informed me of the brake master cylinder recall which I did NOT hear of, so if the brakes had gone out and I wrecked, congratulations, the airbags don't work properly either! Also, not to nitpick but the cheap plastic covers on the visor mirrors both broke off within months of buying the car, I've been a quart low on oil twice when getting an oil change, yet no sign of leaks so apparently it's burning oil sporadically, and now it sounds like the power steering is going out.
Post 7:
Every company has their lemons, but at least our previous two Camrys didn't actively try to kill us. Today in the rain the rear kicked out, nearly turned us sideways on the highway. I know the Firestone has the shims, I talked to another Sentra owner with the exact same problem (Nissan, you listening to this?!) and they fixed him right up, $179 lifetime 4-wheel alignment, took them two hours on a busy Friday. I'm planning on sending a copy of the receipt and printouts of some of these threads to Nissan along with a note to remove head from sphincter.
Googled for "2008 sentra quality"
http://www.edmunds.com/nissan/sentra/2008/consumerreview.html
Performance: 1
Fun-to-Drive: 1
Build Quality: 1
Comfort: 8
Interior Design: 8
Reliability: 1
Fuel Economy: 5
Exterior Design: 8
First post on Edmunds:
Review
my wife was in love with this vechicle. the inside design is roomy and comfortable. the engine at first was great, but after 25000 miles it started with a tapping noise that now has become annoying and loud enough we were asked if it was a decile motor. took it to the dealer ship and they said nothing wrong they even brought in a specialist and he said that it was normal?? very disappointed with the performance of this vehicle. Nissan corp. doesn't want to help. the car car now has burned a quart of oil between oil changes that doesn't seem normal. the vehicle didn't do any of this before.
Yikes! I'd say don't buy, but I'm that guy who buys a Honda because I don't know how to fix cars.
Performance: 1
Fun-to-Drive: 1
Build Quality: 1
Comfort: 8
Interior Design: 8
Reliability: 1
Fuel Economy: 5
Exterior Design: 8
On those review sites you've got to be careful, no matter how great the car is there's always going to be somebody that has had a bad experience. Also remember that someone that is horribly upset is significantly more likely to write a review than people that are happy with their car. When somebody is upset they want to vent so they seek out someplace to rant about it, when somebody is happy they don't necessarily go searching for places to talk about it.
It's better to look at the average review values and compare that to the average reviews for comparable vehicles.
I think the most important thing is to look for problems that lots of people are talking about. For the Nissan Sentra, a lot of people seem to have a problem with the back wheels pointing slightly inward and causing the tires to wear out very quickly. For the 2006 Honda Civic, lots of people complained about rattling noise that sounds like it's coming from the glove compartment; some people explicitly stated that it was a problem in the wheel well. For my Corolla, lots of people complained about the steering or said that the car feels like it's not in control.
Having a lot of people say it doesn't mean it's true, but it's definitely more likely to be true.
I test drove it today, really nice car. CVT transmission really shifted smoothly.
If it feels like it has shifted, that means the transmission is broken.
CVT is an old technology that low powered vehicles have enjoyed for many years. As someone who has driven a brand new quad with a CVT, I can tell you that it should never feel as if it has shifted. Any jerkiness means the band is slipping. The transmission is fucked.
Ok i really misused the word "shift" oops.
Actually I never knew how a cvt transmission works so thats my fault too. I'm not so much a car fanatic but I do have motivation to find that one deal.
I guess I didn't feel a shift persay but how do I describe it changing gears?
Again sorry it did not feel like it was shifting
So will it keep accelerating to its max speed if I have my foot to the floor on the gas? Thats what it was doing, well obviouslyy didn't go to max speed but still...
UPDATE
Underwriters are pending approval. Should I get this car checked by a mechanic or no b/c its still new..
BTW my friend has a honda leased vehicle, anyone deal with a return and if they sting the crap out of imperfections on the vehicle?
