Its definatly busted, i bought it this way, is there anyway i could look into getting it fixed...myself? Its a 1994 dodge shadow!
Call your local garage or dealership and ask them for a quote to replace the sender unit in the fuel tank.Originally posted by: ViviTheMage
thats what my dad was figuring. they rest of the gauges are fine. how expensive, and labour intensive are replacing the sending units?
Originally posted by: Pliablemoose
Most modern cars have a small access panel you can access through the floor of the trunk etc, purchase a new sending unit & replace it.
It's one of those simple things to fix.
Do you have a Nissan? That's where the fuel pump was located on my old Nissan Stanza.Originally posted by: farmercal
On my car that unit can be reached by taking out the bottom cusion of the back seat. Real easy.
If it doesn't have an access panel however, then replacing the sending unit requires dropping the gas tank. This can sometimes be a major PITA.Originally posted by: Pliablemoose
Originally posted by: waggy
heh my wife's car has the fuel gauge broke. it is stuck on half a tank.
so we just fill up every 200 miles.
Your vehicle doesn't have an access panel to the fuel pump/sender assembly. But you don't need to remove the fuel tank either. On the back of the tank you show be able to see the fuel pump/sender assembly. All you need to do is have your fuel level around 1/4 and loosen the fuel tank strap bolts to drop the tank down about an inch. Then you should be able to safely remove the fuel pump/sender assembly without mush trouble.Originally posted by: ViviTheMage
id love to! i just need a little explanation on how![]()
