ManBearPig
1)My car takes 0w-20 and 5w-20. It recommends 5w-20 for winter and 0w-20 for the summer according to the manual, but 0w-20 is like $6+ more expensive. Is it bad if i get 5w-20 all the time? Ive heard its not really a big diff.
2)Are there any brands of oil i should avoid? I get pennzoil i think because its a little cheaper than the other brands.
3)I have a bunch of left over oils of varying weights (0w-20 and 5w-20) that are probably nearing the amount of quarts i need. Can i mix them? Is it bad if theyve been sitting too long?
4)My car takes either 4.5 or 4.6 quarts. Would it be horrible if i just dumped the whole 5 quart container in there?
5)Are all oil filters equal? I just usually get a cheap fram filter from walmart, but there are more expensive frams and other brands as well at other places. Should i NOT be buying a cheap one? We have very easy driving in pretty clean locations (no dust, dirt, etc).
6)For synthetic oil ive heard it has to be changed every 5000 miles. Is this correct? A dude at the store was telling me he changes his every 10-12k miles and his vehicle is at 215K miles or something. He also claims for conventional oil you have to change it every 5-7K miles and that he has 2-3 vehicles with 200K+ miles on them.
7)How often should i change my air filter?
Thanks for the help, more questions will come as i remember them lol.
