car question
Mayfriday0529
7,187
Do you guys think a 2 Ton Floor Jack, is good enough for a Jeep Wrangler or something bigger?
Last winter my friend and i, i got stuck after work with a flat tire on his jeep while there was snow on the ground and also snowing and during that 7f degree weather and his jeep came with this tiny stupid jack that took us about one hour just to lift the car up.
We don't want that same mistake again.
Hankerton
1,814
It should be fine. Wranglers aren't all that heavy. Prolly works fine just for changing a tire. I wouldn't recommend doing work under the car though.
Demon-Xanth
20,551
That's what jack stands are for. Never trust jacks.
Mayfriday0529
7,187
Yeah we only need it in case to change a tire and replace the crap that Jeep put in the car originally.
JDub02
6,209
Get a Hi-Lift jack if it's just for a wrangler. Just throw that sucker under the bumper and go to town. For storage, it fits really nice between the roll bars across the back of the Jeep.
It's even better when you have rocker guards since that's another jack point.
Mayfriday0529
7,187
something like this?
link
