Car Question
Glitchny
Having an argument with someone and need a definitive answer.
Do cars come with restrictor plates to make sure the car cant go over a certain speed?
Are you talking about rev limiter? Then yes, a car cannot rev over say 8k RPM otherwise the rev limiter kicks in.
There are no restrictor plates on mass produced cars I believe....
The PCM (computer) has a set limit on top speed, normally governed by the tires (it will never be more than the speed rating of the OEM tires on the vehicle).
There is also usually a rev limiter to protect the engine, but the speed limiter works outside that.
Originally posted by: LAUST
Restrictor plate limits HP
Rev Limiter limits RPM (My Redline is at 6000rpm my rev limiter is at 5900rpm) once I hit 5900 the engine will cut out like it does when you hit the...
Top Speed Limiter is programmed into your PCM/ECU and it cuts you off by speed, stock mine cut at 100mph but I have programmed mine to 124mph now (H tire rating)
What kind of car is that?
100mph is rather low for stock.
My little Saturn SC2 is 124mph/6750rpm (6500 redline) limiter out of the factory.
Finding H rated tires for a full size 4x4 isn't that easy 😉 (285/70/R16)
Restrictor plates go in Carbeurators, and the only use of them that I know is in NASCAR.
Speed limited is done by the ECU (the engine's computer) nowadays.
the cars are speed limited by manufacs to make sure you don't go over the speeds rated by the fitted tires.
tire speed rating
you car maybe capable of pulling faster than 130, but if your car has h rated tires, the manufacs would limit the speed to 130 to make sure the driver won't run the risk of blowing a tire going over the rated speed.
higher speed ratings aren't always a good thing either, since the compound composition of the tire on higher speed rated tires tend to wear out faster..
as for putting in restrictor plates on a stock car, what manufac in their right mind would drop their horse power/ torque rating to limit the car's speed?
yeah. most cars have speed governors so you dont take it over the max speed (say supported by the tires it comes stock with etc.)
my car has the limiter at 146mph. now you might ask how do i know this :Q
Originally posted by: TommyVercetti
I have heard of some cars which do that. I know the RSX has a speed limiter on its top speed.
Sure does....it is called lack of horsepower and more importantly torque.
haha. doesnt the W(eak)-tec kick in 😉
Hey....get it right. It's V(Vrooooooom)-Tech
for just the sound and no go right? 😉
