CAR QUESTION: Whats the verdict? - Cold air intake or Hot Air Intake?
KDOG
14
Been kicking around the idea of putting an upgraded intake in my car, and have heard some buzz about this Hot Air Intake stuff. Anyone have anymore info? Suggestions?
Heisenberg
10,621
In terms of power alone, a cold air intake is always superior. I've never heard of anyone purposely wanting hot air coming into a motor. Do you have a link?
IamElectro
1,470
Originally posted by: HiTek21
cold air is best but still won't make a lot of power difference.
Especially on the low end. They really only help out above 60mph
HiTek21
4,391
Someone was saying that they could notice an increase on the mid and high end but a loss in the low end but seeing as how I don't have a CAI I couldn't really say.
Brutuskend
26,558
4
Cooling the fuel itself helps produce more power as well.
Hot air?
Seems counter productive to me.
OS
15,581
yeah it's actually supposed to be called a short ram or occasionally warm air intake.
I vote for ghetto airbox cause it's $free.
OMG1Penguin
659
I cut the airbox on my 91 mazda 626 in half so it was like a scoop under the hood. It sounded like this - "whaaarrrrrrroooooooommmmmbbb" Also changed stock air filter with K+N, because it came with the sticker.
Intakes are a waste of money. You're better off buying decals, they will give you more HP/$.
Kraeji
2,092
air intakes give you about 20-30 hp..
only if you have a civic tho.. and you put on the stickers
Aug 23, 2000
15,509
Originally posted by: Captain_Howdy
The best way to make power is to pressurize the intake. Add fuel accordingly.
so turbo charging. Hmmm, I can make millions off of your idea. :p
Pop-chargers=WAI.
the theory is that there is less piping for the air to go through thus making it more efficient and capable of bringing in more air.
Mar 11, 2004
23,444
5,847
"cold air" just means that you are pushing more air into the motor. But the cooler the air or more air you fit in the engine the more power it'll make.
Warmer air is good for efficiency (gas mileage).
Insane3D
19,446
I have a setup in the Mustang that puts the filter inside the fender well. Works well and avoids all the turbulence and heat from the engine compartment..
Pic
Jan 31, 2002
40,819
Pic
Just mind the deep puddles. :p
- M4H
Insane3D
19,446
Nah...it's pretty high up, and where it's located would be hard to get a large amount of water up there. If I never had to drive in rain, I'd probably have the ram air kit.
homestarmy
3,528
artwilbur.com
Wow, none of you guys have any idea what you're talking about.
At least on my car... Acura Integra...
The power is the same, the cold air intake actually doesn't get air any colder, people have measured. The difference is with flow velocity and the length of the tube.
The advantage with the CAI is that you get a little more torque from around 4-5k RPM.
The only time a short ram would be better is if you're running up in the 9k RPM range... the CAI's tend to run out of breath completely up there.
Click here to see comparison on a dyno...
KDOG
14
HAR!!! I guess all I need is a Type R sticker and I'll instantly get 25Hp!!! :)
dmurray14
1,780
I am confused as to who in their right mind would want hot air shoved into their engines...?
natto fire
7,117
10
Actually I stand by my statement. Ask anyone the best way to make power (Especially with smaller engines)and 9 out of 10 times the reply will be boost. I prefer turbochargers myself but a supercharger works just as well. I also have an Integra BTW, and I knew not to waste my money on a CAI. Any power gain from that is rediciously minute compared to a good turbo/supercharger setup.
OS
15,581
I was recently at a dyno day and there was an I4 accord with every bolt on known to man, that made 127 WHP. That's not an incredible number but it was a DX accord rated 135 at the factory so those toy little mods do seem to work and they do add up.
