- Sep 15, 2000
- 1,667
- 0
- 0
I drive a manual transmission truck and got the transmission fluid drained and replaced a couple of days ago. Ever since then, its been really hard to shift into first and second gear. The stick will kind of get stuck and I can't lock it into the gear, or it will feel like the gears are grinding. This usually happens after I haven't driven for a while (such as in the morning). However, once I drive it for a while, it seems like its "warmed up" and the problem goes away. I never had this problem until I got the fluid changed. Did the shop do something wrong or is this another issue w/ my transmission? Any advice would be helpful. Thanks.
