I bought a used 1989 Ford Probe for $800 to drive to work everyday so I don't put miles on my 4Runner.
5 Speed
128K miles
original clutch
previous owner says it has had tune-ups
I wanted to know if somebody could give me some direction on what to look into fixing for the following symptoms.
When I shift from 1st to 2nd at low RPMs (below 2000) there is a clunk sound and I can feel it. (sign on clutch going bad, or maybe needs trans fluid?)
Along the same lines, when I shift from 1st to 2nd at high RPMs (obove 3500) the car doesn't seem to want to catch gear and accelerate for a few seconds.
Another problem is when I let off the gas pedal the engine sputters a little. (Maybe check plugs and wires?)
Thanks
5 Speed
128K miles
original clutch
Thanks
