Scarpozzi
My problem is a car that has 162,000 miles on it. Runs great and has no problems until it rains. It seems that when it rains or there's a lot of moisture the engine kind of sputters when it's pulling out. So it's almost as if it isn't getting any fuel. Flooring the gas pedal makes it worse, but then after about 2-3 seconds it will pull out of that sputtering and act normal again. Weird too cause it only happens when it rains....or when I go on long trips and the car heats up after about a 2-3 hour drive. Then it has similar problems. Help....
More information: 1994 Mitsubishi Galant, 2.4 liter DOHC.
Also, I need to add that I pulled the plugs on this car and inspected them. All are burning clean. I'm expecting this problem to be related to a possible vaccum leak, or perhaps a faulty fuel pump or injector. I'm just not sure if anyone else has had this problem. Thanks for any suggestions. And please don't flame my Mitsubishi....this car would put many to shame. I only bought it because it was 3 years old, had 60,000 miles and I ended up talking the guy down to $4300 when I bought it (my first car purchase).
