- Oct 2, 2003
- 3,692
- 1
- 76
Coincidentally this all started happening the day after I got an oil change at wal-mart..
The electronics shut off while driving.. then shortly after that the engine dies. The electronics don't completely shut off though. It's kind of funky. The spedometer, tachometer, radio all shut off.. Then my seatbelt light turns on because it thinks my seatbelt is unlpugged(which it isn't)... then a half a minute later the engine shuts down.
None of the problem lights turns on. Nothing has ever indicated a problem with the car.
What I've done:
I baught a new battery so that I would have enough power to get the car home. I was able to make it home and it shut down just before my house so I had to coast it in. (did I mention that my power steering dies at the same time the electronics go out?)
So now I think I'm trying to get the alternator out of the car so I can have it tested. I've found 2 bolts holding the alternator in. (allthough one of them is inaccessible without going from underneath the car) I can't get the belts to loosen up. I think I'm looking for some kind of release on the pullies..
Any help or advice is appreciated.
What I've done:
