I just had my car aligned and the print out shows my front driver side wheel has a negative camber and negative caster and I'm also drifting to the right. I'm told by the shop that Nissan does not have a spec for these adjustments for the 99 Altima.
I've been doing a little research on the net and I found out that there are camber alignment kits that are used when people lower the suspension. My car is using aftermarket struts(They were installed before I got the car) I am thinking they were trying to lower the car or they installed the strut wrong. If either were the case would the caster be screwed up too or just the camber?
