Car People, need help engine noise
Jul 12, 2001
10,142
My g/f's 1998 Malibu is making an odd noise when she starts it, it makes a "clicking" noise coming from the engine block, it is not coming from the belt that is on the outside of the engine block.
when you rev the engine it causes the clicking to occur at a faster rate...any ideas?
anyone know of a good mechanic someplace near westwood/santamonica/culver city area?
edit more info:
its been running fine and used a lot recently with no problems, all the fluids are fine
the car has about 75K mileage on in it
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Has the car been sitting for a long time? It might just be a hydraulic lifter pumping up after leaking down. That can take a few minutes after starting.
ZV
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: Pepsi90919
valves or piston slap. wouldn't worry about it.
Uh... If it's piston slap, you need a complete rebuild on the engine, and even if it's "just" an iffy lifter, that lifter still needs to be replaced. If it's something else in the valvetrain it could be much worse than just replacing a lifter.
ZV
My mazda used to have this problem with the valve lifters that made it click like crazy until it was run for a while.
Pepsi90919
ZV
you don't need to rebuild anything for piston slap.
olds
50,128
781
ZV
Just it's eventual aftermath.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
ZV
You mean its inevitable aftermath.
I really hope that this guy doesn't actually believe that piston slap isn't a huge issue.
ZV
laurenlex
2,370
Fill the gasoline tank.
Kill somebody. Or rob a bank.
Engage in high speed chase.
Continue high speed chase.
Eventually pull over and surrender to police.
If the engine lasted through the above, there is no problem and you can live the rest of your life in peace and tranquility.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: gabemcg
could also be exahust related, (catilitic converter or the like)
That ticking is usually only audible during cool-down after the engine is turned off. You shouldn't be able to hear the ticking of the exhaust system expanding and contracting with the engine running.
ZV
Jul 12, 2001
10,142
