- Feb 24, 2001
- 14,513
- 4
- 81
Kinda scratching my head.
09 Corolla with 320k miles.
Wouldn't blow warm air and was overheating so replaced the thermostat (with Toyota part) and coolant.
Worked fine for a couple of days and now back to the same problem.
Gauge looks to go wild. Will rise to the red line slowly, then drop some, then climb, then drop half-way, etc. Squirrelly.
Was thinking maybe air in the cooling system but think it's been purged pretty well, and don't think that would explain the lack of hot air.
My OBDII reader is just throwing E so I guess it's toast and will go to vatozone or something tomorrow and get the code checked out (was getting P301, bad ignition coil which I replaced and the CEL went away for a bit...).
I'm not leaking coolant, and no white smoke, so don't think it's a head gasket or cracked head.
Was about to head to bed but figured I'd throw it out to you folks for ideas.
