Alright, I had serious car troubles this morning which required towing the car to the dealer. When I called late afternoon, they hadn't looked at it yet. So I was wondering if some ATOT car mechanics could guess what the problem is.
Background:
Car is a 1997 Acura CL 3.0. I bought it in May 2000 at 56k miles, it now has just under 90k. I haven't been perfect with the maintainence, but I've been pretty damn good. July 8th, I got the 90k mile scheduled maint done and the timing belt along with the water pump. Cost me a fortune to do all this. This past weekend, I got a notice concerning a safety recall notice over the ignition switch being defective and failing. The dealer didn't think it was too important as they scheduled me for the 26th (called on the 12th).
Symptoms:
On Monday, I noticed something wrong. If I had the AC on, the stock stereo would turn off, the tach and engine temp would drop to zero as if the engine was off and the ABS light would stay on.
Today, it had the same behavior and got worse in about 5 minutes. This time the engine temp was staying steady, but the tach and speedo both were fluctating from telling the real thing to dropping to zero as if the engine was off. The ABS and SRS (air bag) lights came on and stayed on. I didn't even have the AC running and I turned the stereo off myself intentionally. I knew something serious was wrong so I called the dealer on a cellphone and told them I'm bringing it in.
Well, on a high speed road, the car was doing okay except that the gauges were worthless. But when I got to a road with stop lights, and was forced to stop, the engine was idling pretty rough. Then it cut out, stopped. Attempts to re-start it just resulted in clicking noises. No lights would work, even the hazard lights.
Thats about it.
Question:
So what do you think is wrong with the car? I'm just curious so I might be prepared with any BS the dealer might give me tomorrow.
Thanks.
Background:
Symptoms:
Thats about it.
Question:
Thanks.
