Car led mod help
aceofskies05
630
I have a 2000 jetta, and I want to put leds on the front grill to make it look cool. What would be the best way to do this? rig a switch to the inside of the car?
This thread belongs in The Garage. I'm moving it there.
Anandtech Moderator hzl
ViviTheMage
36,189
87
madgenius.com
bahahha, why?!
just hook it strait up to the battery and have a switch go through the firewall....
I would say post on VW Vortex, but they may laugh at you....
DougK62
8,035
Well it took me a minute to realize that you mean LED, and now I'm pissed that I wasted that minute.
shocksyde
5,539
You'd need 4 wires.
One connected to your battery's + terminal, another connected to a grounded metal part of the car's chassis. Bring those two wires through your firewall and attach to a switch somewhere in the cabin.
Then have 2 more wires go back out into the engine bay and to the grill area, where you can attach the LEDs. I hope you're not planning on using blue, because they require a lot more power than other colors and you may only be able to hook up 3 or 4.
Demon-Xanth
20,551
Unless it's built into the LED, you WILL need a current limiting resistor or the LED will fry. Hence my earlier post. Some LEDs (particularly the ones made to replace bulbs) do have the appropriate resistors already in place.
shocksyde
5,539
Not if he wires 3 or 4 in series. I pulled out my dash assembly and replaced the regular white bulbs with clusters of 4 blue LEDs in series. No resistor used and they're still going strong after 2 years.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Originally posted by: shocksyde
You'd need 4 wires.
It is ILLEGAL to display blue light from the exterior of a non-emergency vehicle. It is also illegal to display non-white light from the front of a non-emergency vehicle (the only exception being for amber-colored side-markers and turn signals).
ZV
jtvang125
5,399
51
You'd need 4 wires.
ZV
Don't forget yellow foglights as well. And if I'm not mistaken Ca allows yellow headlights too.
jtvang125
5,399
51
You'd need 4 wires.
ZV
theslickvik
558
First impression "WTF" Secondly, LEDs require lot of time and tweaking. If you have the skills then pm me
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
You'd need 4 wires.
ZV
Technically yellow is not approved for on-road use for headlights. I'd forgotten about about fog lights though, you're right that yellow is allowed for fog lights.
ZV
