Car is acting bipolar.
Status
Not open for further replies.
ProchargeMe
Okay the car is my daily driver, a 2004 mustang mach 1 and 3 days ago i was driving in the city and i pulled up to a stop sign and put the car in neutral, it cuts off completely, i lose power steering and power brakes. I try to crank the car and it turns over but sounds terrible, almost like a rod was knocking. So i call the towing company and get the car towed to my house, he drops it off and i try to crank it again, it fires up but my power steering and brakes were still dead. At this point the radiator starts leaking and i filled it up twice to try and find the source of the leak, i couldn't. Third time i fill it up it stops leaking, i drained it and filled it up again just to be sure. And magically it stopped leaking. My power steering and brakes both needed fluid but only because it spewed it out when it broke down. I've driven it around the neighborhood since it stopped leaking and everything is running great, like nothing was wrong to begin with, but I'm hesitant to drive it to work right now.
TL;DR
1. Car breaks down
2. Makes awful noise when trying to crank
3. Radiator started leaking
4. Radiator magically stops leaking
5. Car is fine
6. Wtf
so power steering fluid and brake and coolant leaked and stopped leaking simultaneously ? Do a coolant pressure test and get some degreaser on the engine and clean it off so you can see where things are leaking.
Status
