Originally posted by: Tyler
There is no difference, all three of them translate to "shiny metal tube worth $10" that cost $199, and do nothing for performance.
Actually a cold air intake paired with a high flow exhaust are good for a HP increase. What that increase is can be debated time and time again. Dont believe the rice though, an intake alone isnt going to turn your 4 banger into a street rod.
Your car-modifying credentials, please?
So the intake SLP put on Firehawk Firebirds was useless![]()
You really think he's talking about a "properly set up car" and not talking about an anodized blue aluminum tube to stick under the hood of his completely stock 93 accord (or similar)?Originally posted by: Heisenberg
As was apparantly the ram-air intakes on the WS6's and SS's, as well as all the cowl induction setup's from the 60's and 70's.![]()
On a properly set up car, it can make a difference.
No, but you didn't specify if you were talking about that in particlular, or just in general. If you were/are referring to sticking a piece of metal pipe in a stock honda/toyota/etc. then yes, you're right.
I figured that's what he was talking about. You ever hear an LS1 driver ask a question like in the first post?
I don't mean to say that intake piping can never make a difference in the performance of a car, just that it wont in his case (and pretty much all cases where someone asks about "cold air intake")
Most of the ram air stuff from the 60's and 70's were marketing gimmicks. Cowl induction? Please. Chevy tried to convince people it worked. It didn't.Originally posted by: Heisenberg
Hahaha! Ok I will be serious now.Originally posted by: nan0bug
Well, I don't know about just a warm air intake, but if he installs a cold air intake or gets a cowl induction of some sort, and he follows it up with a higher flow exhause, he should see a hp increase. Whether that HP increase will be minor or major depends on a lot of other factors, but he will see one.
As far as my car credentials go, I've got an 88 z24 that I'll have to post pictures of sometime. The transmission died on it so I don't know how much more work I'll be putting into it. I may just say f#!$ it and get myself a mid-90s Impala SS instead 😀 😀 😀
