Car Indicator Problem
Also, i don't know whether its worth noting.. My right side dipped beam bulb stopped working (the same side as the indicator problem), not sure if its blown or its a fuse or what, haven't looked that closely yet.
It could be just a coincidence but maybe related?
What is a "dipped beam"?
In most cars the flashers will flash really fast or erratically if there is a voltage change across the lighting system. Happens when people replace their blubs with LEDs.
Originally posted by: oldsmoboat
Flasher or one of the lights are out.
or just loose in their sockets. worst case its the cam on the steering column or a connection from the fuse block. either way not a huge deal, just not fun to find
Sorry dipped beam is just normal headlights. I havent replaced any bulbs recently, having taken a closer look it seems the problem only happens when i have my hazards on, when im just indicating normally it seems fine.. strange. 😕
