Originally posted by: jai6638
seriously how would i find out?!
😀Originally posted by: Oger
Remove the cylinder head(s) and count the number of pistons.
Originally posted by: SampSon
4 or 6 liters?
my bad 😛.. fixed it..
Originally posted by: Slvrtg277
Or count the valves and then divide by 2. There's an equation out there somewhere if you google for it. Something like mph/tque*gallons of fuel or what not.
Because Oger stated the most excessive way to find out the number of cylinders in a engine. I would recommend taking the VIN and calling your local Honda dealer and ask them for the engine size and type.Originally posted by: jai6638
i see .. thanks
whats the smile for?
Originally posted by: Toastedlightly
First you pop the hood.
Then you hold the hood with your hands.
Now look at the engine.
Last drop the hood on your d!ck because you dont' deserve one.
