Originally posted by: Sluggo
Sounds like maybe the contacts on the key mechanism are on the fritz, shouldnt be too expensive to yank that one out and replace it.
Originally posted by: ausm
Battery is dead possibly because the alternator is fried
Ausm
That's a 'neutral switch', but that shouldn't be the problem. Quick way to test that (and the only reason to test that, IMO, is because it's very quick and easy) is to start it in neutral.There's the clue. Sluggo may have it with the ignition switch, but it could also be the transmission's "in park" switch.
Originally posted by: crumpet19
sounds like a bad the rotator splint.
you should have that checked out.
Ausm
Check both of those outm, they're the easiest.
Originally posted by: rudeguy5757
wont start in neutral either...that was the first thing I tried...and yes all the lights come on so I know its not the battery..and once it does start up it cranks and turns over just fine...i was thinking maybe it was a relay that just froze up seeing how it hasnt been above freezing here in almost a month
