imported_Lucifer
I drive a 5spd 87 Honda accord. I don't know much about cars, so I hope someone can help. Anyways, I am assuming that the shift syncros is going out. 3rd gear grinds rather loudly, although it does it sometimes, but most of the time it grinds. 5th gear ALWAYS grinds. No way to stop it from doing it. Reverse will grind, only if I don't alternate between 3rd and 4th then shift to reverse. 1st and 2nd gear are perfectly fine.
anyone know what might be the problem? I got a new clutch maybe about 30,000 miles ago, and although it helped a little, it didn't completely eliminate the issue. and the car is at about 236,000 miles.
thx
thx
