Okay, its about time for me to change the tires on the car I have. I've got a 97 Acura CL 3.0, and it currently has on Michelin Energy's. The tires are okay, but the wet condition handling is pretty poor. Which is a problem now that I've moved to Long Island from Phoenix.
So I was looking around and found the Bridgestone Potenza RE950's which look like a good replacement. Only catch is, my car currently has on V rated tires and the Bridgestones are H rated.
So I am just curious if this will make any problems for me? I doubt it since both are rated 130+mph, but I figured asking wouldn't hurt. Especially since a few tire selection engines don't even provide the Bridgestones as an option.
Just in case you are curious, my car takes 205/55R16V.
Thanks.
Thanks.
