I have a 1988 Toyota Corolla FX with a 1.6L 75hp engine with a carburetor. It's fast. 😀 Here in Ohio we have this stupid emissions testing program called E-Check. While emissions testing is probably a good idea, the way E-Check is run is just horrible. Anyway, my car failed this lovely test today.
The first E-Check we did on the car was in June of 2002. Here are the results:
Hydrocarbons: 7.6 ppm out of 206 ppm allowed
CO: .03 % out of 1.33 % allowed
CO2: 14.11 % out of no maximum
NOx: Not tested
Here are the results from the test today:
Hydrocarbons: 72.1 ppm out of 206 ppm allowed
CO: .19 % out of 1.33 % allowed
CO2: 14.24% out of no maximum
NOx: 2538.7 ppm out of 1512 ppm allowed
As you can tell, the NOx test failed. Also, the hydrocarbon and CO readings are up significantly. What would cause this? Any tips on how to get these readings down lower? E-Check basically gives no information on what causes the different emissions.
From what I have learned, having a completely warmed up car is important for lowering emissions. My dad (who got the car tested today) said that he drove the car to the E-Check center (about 10 minutes away at highway speeds), turned the car off for a few minutes while he waited, and then went and had the test done. Can I assume that the cooldown from having the car off a few minutes was enough to increase the emissions atleast somewhat?
NOx: Not tested
