- Oct 21, 2006
- 5,401
- 2
- 0
My girlfriends 2003 Malibu 3.1L V6 with ~150k miles randomly died about half a mile from my house on Thursday. She said it started to choke and sputter, then died completely, and would crank but not catch when she tried starting it again. Prior to this, the car has had virtually no problems.
The car cranks with plenty of force and all accessories work fine, so it's not the battery. The car started and ran for ~10 seconds when I sprayed starting fluid in the throttle body, and was even able to rev to 4k with no hesitation / skipping / etc., so it's not the starter or something crazy like a thrown rod. Oil and other fluids are fine, no CEL, and no visible leaks.
When we turn the key to "On," I don't hear a whine for the fuel pump, but it was a noisy area so I couldn't say for sure. I swapped the fuel pump relay with the horn relay (same part) just to be sure that wasn't the problem, and it didn't help. After several tries with starting fluid, I could hear the fuel pump making some kind of "thumping" noise, kind of like a water pump sucking air. The car has a 1/4 tank of gas.
We picked up a replacement fuel filter (presumably never changed) and I will pull a line and see if it squirts any fuel to test the pump. Other than that, anything we should be checking for?
Thanks.
Thanks.
