car died as i pulled into my apartment driveway...
Turin39789
12,218
8
Originally posted by: redly1
fuel filter or fuel pump?
just throwing that out there
Could have been, if some sediment stopped up the fuel line for a moment and then settled back down overnight. But I don't know how common that is on modern toyota's, it's definetly a possibility but I don't know how likely it is.
TheNinja
12,207
Not the alternator, in fact your coworkers are idiots ;)
My guess:
Fuel filter problem (or injection clogged)
Air problems (possibly Oxygen sensor?)
It sounds like when you pulled up it just couldn't get enough gas or air. What do I know though.
nakedfrog
59,132
13,702
I was wondering about that myself, but I'd really hope that the 150k service would include a fuel filter.
Hyperlite
5,664
This used to happen on my mom's 94 chrysler town and country, and on my isuzu rodeo. after driving for a period of time at a constant velocity, you could pull in somewhere and it would just stall. It was a valve getting stuck from using cheap gas and getting gummed up. had them de-gunked and started using a different brand of gas, problem solved.
or it could be on onboard computer error, or a fuel pump problem.
SonnyDaze
6,867
I'm no mechanic but that's where I'd look first (fuel system) rather than electrical (alternator). How full/empty was your gas tank? I've seen vehicles that would die ehn making a turn because of low fuel (fuel goes to one side of tank---no pickup of fuel). Also have the fuel filters/fuel pump looked at.
