Car diagnostic question, puddle under car, under front.
KLin
30,491
780
condensation from your A/C because you're running the defroster would be my guess.
VirginiaDonkey
1,704
what color is it?
clear= water...no issue
green or orange= coolant....issue
brown or black= oil.....issue
ohtwell
14,516
9
Originally posted by: 0roo0roo
its err well i guess clear. ground is dirty so its kinda dirty too:p
Grrrr... can't you answer a simple question??? ;):p:D
It's probably just water.
: ) Amanda
0roo0roo
64,795
84
and tranny fluid is the other dipstick right? and its oily too right? if so that can't be it
Injury
13,066
Put an old coolwhip/butter/gladware container or something underneath it and get a "pure" sample.
Where does it seem like it's coming from and make/model/year
0roo0roo
64,795
84
guess i'll try using a container. can't check location, its been moved.
its an 89 camry
