Car cooling question.
f1y
Banned
Oct 9, 2005
233
Anyone know the freon level to put in the evaporator on a 94 toyota camry?
this has been googled, looked up in owners manual, and the chilton repair book. Nothing on it.
GalvanizedYankee
6,986
Just switch over to the 465 system. 4 windows down & 65mph :D
Was this post intended for OT??
Your system maybe R-12 or R-134A as '94 was a change over period in car production.
Let someone evacuated, repair, then re-fill the system.
...Galvanized
f1y
Banned
Oct 9, 2005
233
R134a, I'm using the cooling out of the car :) But I don't know the refrigerant capacity..
Luckyboy1
934
You add it to the low pressure side and just keep putting it in until it won't accept any more.
sparkey
82
find a import mitchell manual and in the front of that specific car it will tell you how much ref. and oil it needs
f1y
Banned
Oct 9, 2005
233
took 1.19 Lbs i doubt that how much it full takes, but through the sight glass i see no bubbles.. working good for now.
herm0016
8,489
1,106
too much and it will freeze up the condenser, could break the lines. ask a local mechanic. and make sure you evacuate the system before you charge.
lenjack
2,706
7
I guess you think some of us computer folks know something about cars...yeah, some of us do.
Did you really mean to post this here? :))
GalvanizedYankee
6,986
If you opened the system, the dryer should/must be changed. I would not fill past the sight glass clearing as performance will drop off. A few bubbles every once in awhile is not a big deal.
...Galvanized
