Car charger sets van on fire
Status
Not open for further replies.
MotionMan
17,124
12
My wife just got a forwarded e-mail just like the OP in this thread.
Is this legit or an urban myth? (If it is legit, I figure they had the charger plugged into an always-on outlet, but there is not enough information to determine.)
Discuss. Rinse. Repeat.
MotionMan
PottedMeat
12,363
475
There are always-on outlets in cars? Seems like a bad idea since there are so many 'dumb' power adapters that will draw current as long as they're connected. Forget about the load for a while and your battery's dead.
I guess it's possible, maybe with a cheap linear regulator non heatsinked in a plastic housing. 12V -> 4.2 or whatever @ maybe 1A charging current. But it would probably have a thermal shutdown though.
I bet there was a wiring problem in the dash.
and finally, they're still putting those ugly ass fake wood panels in dashboards?
l0cke
3,790
I thought this would be about superchargers or turbochargers. Disappointing.
marvdmartian
5,444
27
Originally posted by: coxmaster
It might be.. but then again, it might not be..
In other words, it's a definite MAYBE. :laugh:
Most (if not all) cars I've driven still supply power to the cigarette lighter (aka power point) when the ignition is off. That being said, any power plug that plugs in to charge another item is going to get hot during it's use (check out the power pack for a laptop sometime).
Whether that heat is sufficient to cause a fire, I cannot say. If I had to hazard a guess, I'd say that the charger was cheaply made Chinese garbage (like most stuff these days), had a short, and caught fire.
So there's your answer. Maybe.
tasmanian
3,811
The dock should not get anywhere near hot enough to catch fire. In most newer cars after 30 or so minutes the cigarette lighter gets the power turned off.
TallBill
46,017
62
Right.. that's the point.. it shouldn't, but it.. did?
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
I wouldn't blame the charger so much as a battery failure. Li-ion batteries have a small chance to overheat when overcharged, so it could be real.
Status
