ok, so most of us should know what electronic brake distribution (EBD) is. simply put, the computer adjusts individual wheel braking depending on the situation. now, one thing i've always wondered, has there ever been any manual brake distro systems?
what i was thinking, is motorcycles always have front and rear brakes. when racing, the way you use them is extremely important. want to take a faster, tighter turn? then pull the front brake and it'll pull you into it. need to slow down and straighten out? a little more back brake helps.
now, this is a lot simpler on a bike because of the way you ride and control it, but, has something similar been implemented on a car? i mean, does it not make since to be able to control the front and rear wheel brakes differently? drifters often utilizing the hand brake (rear, non hydraulic, break line) to help whip the rear end out. but what if you had a brake peddle (or hand brakes on the steering wheel) that if pushed in the center hits both brakes like it always would. but, if you so desired, you could hit the left for rear and right for front. i suppose if you could eat with your hands you could make a four peddle version for all the wheels, but that is just too complex.
what does AT think?
what does AT think?
