Car battery charger recommendations
Status
Not open for further replies.
Kaervak
My dad left his lights on and drained his battery, I stole my uncle's 2A/6A Schumacher charger and all is well. However, incase this happens again I'd like to get my own battery charger. Any recommendations or brands to stay away from? Around $50 would be nice, but I'm not dead set again something expensive if the quality is good.
Originally posted by: SoulAssassin
Do you want an actual "charger" or do you want something to jump it? I have the Craftsman below and have been happy with it. Currently on sale for $45.
http://www.sears.com/shc/s/p_1...+Chargers+%26+Boosters
A charger is adequate. However the jump feature would be nice as my dad's car is a V8 and mine is only an I4 and I've always been under the impression that you shouldn't jump a larger vehicle with a smaller one. Any truth to that?
Anyway, I've been looking at Schumacher chargers on ebay and there are quite a few previously used ones that are rather inexpensive and are plenty capable of what I need. Any other brands worth looking into? Are the cheapo harbor freight chargers worth anything other that a laugh?
55 amp setting provides enormous additional cranking power when working on autos or in emergency situations
Not enormous at all and
Not through them thar little wires... 😀
That looks like 14 gauge wire for the clamps... holy firehazard batman.
I've got the blue one form harbor freight, 2/5.5 amp
Hmmm...I never actually used a charger as opposed to a jump start.....with the charger, do you just hook it up to the battery and let it trickle charge for 5 minutes?
For a tricke rate it will be overnight.
Depending on how dead the battery is, and the normal rate of the charger, it could take anywhere from 30 minutes to a couple hours to get the battery strong enough to crank your car.
A high rate fast charger might do it in 10 minutes, but those usually have the jump start ability anyway.
Personally, I would just get a jump starter and then run the engine for 30 minutes to let the alternator do the work unless you are using it for a mower or a vehicle that doesn't get driven often.
An alternator only provides a trickle charge. 30 minutes will be enough to replenish what a battery lost to start an engine but not nearly enough to bring back a battery that went dead.
ZV
Well, I went with a Schumacher SE-70MA 10A Fully automatic charger. http://store.schumachermart.com/se-70ma.html It does 24v deep cycle too. The best part is I got this lovely bit of overkill on eBay for $22 shipped. One little mark in the metal casing and that's it. 🙂
I had no idea just down discharged my dad's battery is, accoding to the charger it's only about 25% charged. I guess I just got it charged enough to get it to crank over and replenish what it took to start it but not much more.
Well, you aren't charging a deep cycle battery. Not sure whether that's really a problem or not.
EDIT: Nevermind, it charges both so you're fine.
Status
