car battery - are they all basically the same?
michal1980
8,019
43
looking for a new battery for my wifes 2006 scion xa.
It seems like in that size battery all the offerings are bascially the same. Sure there is a red top that fits. But outside of that sears/walmart/advance all carry basically a 24 month warranty battery with 550cca. At this point do I just shop by price?
Jimzz
4,399
190
If it has the same or more CCA and a decent warranty then yea pretty much the same now. So many battery makers have been swallowed up I think there are only 3 major ones left. Just don't buy the economy battery and you should be fine.
Advance with its coupons and Costco are my 2 go to now.
LTC8K6
28,520
1,576
Yes, there are not many battery mfgs. Most of the brand names are made by the same 2 or 3 companies.
The Wal-mart battery with the 2 year replacement warranty should be fine.
michal1980
8,019
43
Neareast costco is ~20+ miles away, far away enough to be a PIA to get to.
michal1980
8,019
43
thats kind of what I figured in my research.
Nothing but 'silver' level batteries for the xA either.
Slacker
33
Get a price on a battery from the dealer, you might be surprised.
Midwayman
5,723
325
Generally there are 2-3 levels of battery. Different CCA ratings per battery. Beyond that shop by warranty and price. If you have a particularly demanding application (like a big stereo you'll be running with the engine off or bags, etc) you might look into brand a bit more.
ummduh
83
Short answer; for you, yes they are all the same. Match the oe specs and have fun. Shop via best warranty for the money.
Long answer; no, there are many many different types and design of batteries out there.
rsbennett00
962
I just bought one recently. Interstate wanted almost twice what sears did. I'm a walmart boycotter so no idea there. Sears had the best price per warranty, 4 years 0 cost and prorated up to 10 years. The one I replaced lasted for 7 years before I got tired of the slow starts.
evident
12,130
749
costco, their batteries are made by johnson controls, which i think is a major manufacturer for many other car battery brands.
silicon
886
yes batteries are all similar and the CCA is the spec to look for. Also batteries will degrade over time when sitting on the shelf of the store. like produce and other perishable items the newer the better.
eng2d2
1,007
38
Costco to me is good enough, not the best but I don't have any complaints.
tamm
439
advance auto FTW as it has tons of coupon codes to make it under $80 for a new batteyr
RLGL
2,115
322
Interstate is also by Johnson Controls
No not all the batteries are basically the same. You get what you pay for.
I had a long conversation with my Interstate driver. There are a lot of differences in the batteries that affect the pricing.
