i have a 1989 Ford F-150 and not even the ex-cab so i have no space at all. I did find a box that will hold 2 12" subs though that will fit perfectly behind my seat! I am also on a very tight budget. The box is $50 after shipping from www.speakerhole.com can anyone recommened cheap 12" subs? they can only have a max depth of 5.5in. I was looking at Rockford Fosgate for an amp. there 2001 models are much better than last years i heard. I was looking at Audiobahn subs and they are pretty cheap and had good reviews. anyone have these? The AWC12X(500w RMS, 25-800hz, 92.9db, 5 1/16 depth, 2 or 8 ohm) looks to be pretty good. I can get them for $62 each. The rockford 800.2 can push 400w RMS at 2ohm per channel which i think will be more than enough!
Can anyone recommend anything better? Does anyone have any of this and tell me how it performs?
Thanks
Thanks
