Car audio: What speakers??? And amp to power them?
BadNewsBears
3,426
So this is what I have decided on so far. Either go the alpine route of two type r 12's and two alpine m-300 300 watt mono amp's. Ported mdf box I will make, and eventually if it's not enough, then ill add one more 15' type-r with appropriate mono amp.
OR
Find some (3) diamond audio mac daddy 12's (not in production anymore) and use those.
My question is, what speakers do I use. I have some holes ( albiet very sh!tty cutting job by PO) for 6x9's behind the rear seat, I think I'd rather cut nice perfect holes in the door bottoms. or, I can run all four. There all 6x9's. What speakers? Infinity kappa's? Anything better but in the same price range? And what amp to power the 2 or four speakers?
MikeMike
45,885
66
RE components are supposed to be very very good for 150$
reaudio.com
as for an amp im not sure right now, there are a lot of good ones.
MIKE
glen
15,995
For speakers:
JL, MB Quart, Boston, Alpine
I have the JL's.
For amplifiers:
The most inexpensive amplifier that has enough channels.
I have no idea what brand of amplifier I have, or its power output.
I think it is 25 x 4.
I never have to turn my system all the way up.
HoodRich
Banned
Sep 12, 2004
64
reaudio.com
boi dont talk crazy i dun read comparison dat dem type r comps actualy more smoove den da res dem res imaging is not near good as durr subs mang
dun fuhget RE has awful warinty service dey deny pretty much errythin
HoodRich
Banned
Sep 12, 2004
64
boi whut da funk u talkin
u best not said u gonna mix sizes of subs u mos likely get dem cancellation less ya goo installer n got ur filter right
RagingBITCH
17,618
reaudio.com
Would you mind "unghettofying" your lingo, jigga?
HoodRich
Banned
Sep 12, 2004
64
btw dem type r 12s take a beatin
i dun sent 2000w rms and i aint talkin no pyramid ish to dem for burps and dem take em but o cours u still smell em burned vcs mmmmm goo smell mang
HoodRich
Banned
Sep 12, 2004
64
reaudio.com
BOI IT SPOKEN REA CLEER 2 ME!!!!!!
whut u need help wif
MikeMike
45,885
66
hoodrich. STFU motherfvcker you are the most annoying piece of sh!t on this website EVER, yes ive been here a while and you are by far the most annoying thing ever. A: you dont know what your talking about. every review ive read they are compared to 300$ components.
type r comps are not the best ever. imaging is fully dependent upon install and not the components themselves. RE has a great warranty, they just know if a sub has been abused or not, yet they will help you out 99% of the time.
mixing subs is not the best, but you can overcome cancelation, and 12's and 15's wont cancel, i dont get where you get that. and what filter? there are tons of filters.
any sub can take 2000watts, just not for long. if your not talkin pyramid what are you talking? sony? rockford sans power line?
MIKE
HoodRich
Banned
Sep 12, 2004
64
dump da 6x9s waste o green mang
imaging suppos 2 b in fron of ya unless below 60hz den nondirectional boi spen moe gree green on dem comps n moe powah 2 dem.
HoodRich
Banned
Sep 12, 2004
64
mixing subs is not the best, but you can overcome cancelation, and 12's and 1's wont cancel, i dont get where you get that. and what filter? there are tons of filters.
MIKE
haah boi u dun kno who u talkin too
shoot playa i run 500 dolla comps with 250w rms to each side playa and i kno my imagin, sumfin u DONT kno
type r comps are not da bes eva but they smootha output den dem res guarentee
u better get yo ish togeth to mix em up subs n make sho u got yo boxes righ n em frequencie righ i bet u put em on tl befo n afta the addin da 15 u get some surprisin #s boi
HoodRich
Banned
Sep 12, 2004
64
MIKE
btw playa im burpin dem r's at 2000w at .5 with 15v chargin system courtesy of RE 35.1 playa
don hate me cause i kno my ish
Crusty
12,684
MIKE
At least he knows English...:confused:
MikeMike
45,885
66
MIKE
name the 500$ comps. i would so just rather not talk to a fvckin flaming (word i cant use) and just ignore it but not one person on here is liking you.
if you run 250 watts to each side i would love to know what you use to power them and how many watts your running to your sub? also, where are they located because imaging is very difficult. are you running an eq? if so ,pro audio, or car audio?
MIKE
Aug 16, 2001
22,505
4
MIKE
What are you trying to pull here on the boards n00b?
English motherfscker, DO YOU SPEAK IT!?
HoodRich
Banned
Sep 12, 2004
64
MIKE
MIKE
playa i run cdt ef61cf with satnet 560 and tw-25 upgrade ya dig with pg t500.4 dat way if i wanna say fughet dem satnet 560 i can thro em out and boom i got direc powah to tweets n mids n tune it betta
gonna do it jus lazy ya dig i dun need external eq i got pio premier p860 with 13 band parametric eq
haha u mad cause ghetto g smarter den u
KEV1N
2,932
If I read correctly, you want to get 2 12"s and power each with its own M300. Why not get one JBL 1200.1 or similarly powerful amp and run the subs with that? Also, 2 12"s sounds like a lot of pressure but might get sloppy. However you may have more experience on the subject. I have a entry-level Infinity Reference 12" (#1230W) and a JBL 600.1. For aesthetics I'd choose an amp from the Alpine v12 line to match your sub amp(s). Plus they have a lot of options.
38
i had 2 12" type r's last year ni a ported box, with a sony class D amp, hit good and most importantly(to me) it hit just about every note very smoothly.
but the best speakers ive ever had were 2x mtx 15" 6000s with 250 watts going to each, ported box, OMFG it was loud...knocked my rearview mirror off and what not. cheap too.
alpines are quality sounding subs.
hoodrich, you have decent information/suggestions but we dont speak that kinda garbage here, try tuning it up a bit.
TEEZLE
2,536
If I were you, just get a pair of the Type-R and hook them both up together to 1 amp. You can get a decent amp for the same price of the two you want to get.
Edit: It's kind of hard to give you a ballpark without you saying how much you want to spend. Maybe if you tell us your max on everything we could help you better......
Edit #2: nourdmrolNMT1 you have a PM
BadNewsBears
3,426
Well maybe a limit of $1200 that includes fatmat liner, and some liquid fatmat.
