Well after making the final improvements on my home audio setup and being pretty happy with what I have for headphones for portable use I've decided I'd like to upgrade my car's audio from the factory to something a bit better. The thing is I have zero experience when it comes to working on cars (aside from swapping out the spare tire) and I lack a garage so I'd be working on it in an open parking lot which I'm not too sure if it's a great idea. The car that this will be going in is a '02 Stratus four door sedan. Hopefully I can be guided a bit by these forums and get some general questions answered.
1) I'm looking typically at a DMR to replace the headunit. The only reason I use CDs nowadays is to burn the FLAC files from my collection onto CD so that my car CD can play it. It'd be nice if the DMR could play FLAC but I can deal with it playing back MP3s instead since I don't think I can budget for the same level of music fidelity I have at home. Feature wise I'm looking for bluetooth and USB which seem to be included in most DMR head units. Brand name wise I'm looking primarily at Pioneer & Kenwood although I'll take other suggestions.
2) I'd also like to replace the stock speakers with something a bit better. The thing is I'm not sure what's a reasonable amount to spend on decent car speakers or what's a good brand name. I've seen & heard various speakers from MB Quart, Pioneer and some other manufacturers but I'm again open to options. I'd be replacing the front & rear speakers on this vehicle. The fronts are 6 1/2" coaxials (I believe at least) and the rears are 6x9 speakers mounted in the trunk. Sound wise I'm looking for I guess you could say decent all around speakers. I'm not looking for heavy bass so at this time I'm going without a subwoofer but I do want clear vocals with a good amount of high frequency response. Bass presence would be nice as well.
3) Where to purchase this all from? Again I'm not so sure it'd be a good idea for me to try and self install it since it would involve disassembling front door panels to a degree for the front speakers, getting inside of the trunk to install the 6x9 speakers and removing the factory stereo from the console. So I'm looking for potentially a local shop to purchase this from in the Denver area. So far I've looked at Quality Audio Sound but I'm open to other shops although the last time I did a car stereo install with Best Buy the install quality was a bit lacking so I'll be staying away from them.
4) Budget. Installed what is the typical budget for a system like this? A headunit install alone from Quality Auto Sound was $300. This was for a Kenwood eXcelon headunit + parts & labor. The headunit by itself was $190 so that's $110 for parts, labor & taxes which to me seems on the steep end, but I could be wrong. I was hoping to get a setup installed for around $400, is that too little for a decent system?
