Originally posted by: NutBucket
Speaker level inputs.
Not noticeably.Originally posted by: phreakah
that's what i told him.. does this affect the quality of the speaker you're inputing from?or is there a way to fix that?
Originally posted by: KEV1N
Basically you need:
1. Amp wiring kit - just like any other situation. Run power and ground.
2. Amp - Choose one with speaker level inputs and auto-sensing turn on-- this removes the need for a remote turn-on lead, which most stock stereos don't have.
Tap the rear speakers using Radio Shack low-voltage tap-ins, or splice the wire.
3. Subs - Your choice
I just installed an infinity basslink, (Self-contained 200W amplified subwoofer, 10") into a friend's 03 Accord with no other stereo upgrades. Very simple.
Basically you need:
I have an Infinity BassLink in my bravada... I am very happy with how it sounds.
