Car audio people
Alpine CDA-9847, but if you can live without sub preouts, changer controls, and the optional remote, the CDE-9845.
<----Alpine whore
<----Alpine whore
I can live without the changer controls and remote, but I dunno if I need sub preouts or not. I plan on hooking up 2 10" subs and an amp, so is that something that I need?
Having sub preouts is nice, as long as the HU in question has a sub level control. Sometimes you want to change the bass level, and it's nice to do that from the front seat.
Originally posted by: UglyCasanova
Originally posted by: Shawn
Pioneer DEH-P6700MP
Is there any difference between it and the 4700MP other than the display?
Not sure. The 6700 does have EQ-EX though. That does make a difference. It is always turned on on my 750MP. Also the OEL menus are very easy to navigate and use. I dunno how they are with the 4700.
<----Alpine whore
If you're going to get a sub then get a HU with sub outs. Makes life much easier. With my 750MP I can adjust the sub level very easily as well as the low pass filter. I adjust my low pass filter every now and then depending on the song, so that's nice to have too.
edit: wow, didn't realise Pioneer got rid of their sub outputs. If I were you I'd get last year's model off ebay.
Ok, I think I am also getting 2 10" Alpine Type R's (or if you have any other recommendations), and what amp should I get to power them (that is not too expensive).
I have a pioneer and I love it (with 2 factory 3.5" speakers and 2 cheapo pioneers). Just wish my car was working so I can listen 🙂
