Originally posted by: chiwawa626
I drive a 1992 ls400...it comes standard with an 8 inch subwoofer in the back. I duno how that effects the installation or how the heck i install it. I need some good literature on this sort of stuff and some how to's.
How do i know howmany watt amp to get, whats better series or parallel?
Well, your woofers are 350rms right? So, get an amp that pushes up to 350 watts rms. You don't really need two 350 watt amps or anything. Well, for one, how much do you plan on spending? Assuming a limited budget, one option is this:
4x85 watts RMS amp, bridge the channels, so basically you'd have a 2 240w channels, one for each sub, also assuming a 4 ohm load. You would just wire each sub to each bridged channel normally. That should give you all the power you need. And the amp is only $175. You might be able to find it cheaper elsewhere.
Get a wiring kit for the amp. Personally, I would find a shop and just pay them. It costs around $75-100 total for the amp kit and install.
You could have them mount the amp under the rear deck.
Do you have a factory head unit? If you do, I think they sell an adapter that will convert speaker level inputs (the speaker wire) into an RCA plug, so that you'll be able to hook the amp up to the head unit. The speaker wire leads going to the factory woofer would go into the adapter, then plug the adapter in the amp. I suppose I'll search around and see if there really is such a thing.
edit: I didn't find any before I got tired of looking. If there is no such thing and you have a factory head unit with no RCA outs, the easiest way to install the stuff would be to just get an amp with speaker level inputs and do like I said above. Otherwise, you might invest in a nice head unit. Get one that decodes MP3s.
