Car audio help
rh71
52,844
1,049
'08 BMW X5 with stock amp/speakers. Recently had rain water get into the left rear trunk compartment (clogged sunroof drain) where the amp and all the wires are housed. It wasn't submerged but it got wet for sure. Had this happen many months before and my speakers came back fine. This time, after a day of speaker buzzing (from being wet), it dried but my left front & left rear speakers are very low (balance left/right tested). Additionally, the front center speaker is crackling but that may just be blown (weird coincidence though).
I ebay'd a replacement amp (also from an '08) and the exact same symptoms remain. Car audio shop (via phone) is baffled too that a "new" amp didn't fix the left speaker low volume issue. I'm more concerned with that because the center channel I assume I can simply replace the speaker.
Any ideas? Could it be the harness plug that goes into the amp? Guy made it seem like speaker wires once dried should be fine.
Stock amp looks like this: https://ebay.to/3jAjsk9
Harness:
herm0016
8,524
1,132
wire should be fine, have you left the trunk open so it can really dry out? tiny brush to clean the contacts may be worth a shot.
could have shorted in a way that put too much current to the speakers and blew the voice coils. may want to pop the easiest one out and check the resistance between the terminals, and from terminals to ground.
rh71
52,844
1,049
I've put in a 3rd used amplifier and the symptoms are exactly the same so it can't be that either. I will order a new speaker and test. If I'm only getting lows and no mids/highs, does that point to a tweeter issue?
Back to the other problem with the center channel crackling, is this a speaker or tweeter issue?
(0:27 you can hear it clearer)
