I am a newb when it comes to car audio but I and a quick learner. I know how to hookup the amp power wise(at least I think). Run wiring from the battery to the amp with a 20-30amp or so fuse a foot or so from the battery. Ground it to a seat belt bolt is best but to the car frame somewhere.
But what I ain't sure about is hooking the sub to the amp. Say I have a 2 channel 200watt amp. I want to hook a 200watt sub to it how do I bridge the 2 channels so I can hook it to the sub?
Also if I was to buy these:
http://www.walmart.com/catalog...gsp?product_id=2569443
And these:
http://www.walmart.com/catalog...gsp?product_id=2569442
And hook them to say this:
http://www.walmart.com/catalog...gsp?product_id=2569436
Would the radio alone be able to push them enough? Or should I consider a 4 400watt or so amp for the speakers and a 200watt amp for the sub? If so how would I power 2 amps? Or should I just go with some weaker speakers that the radio can handle?
Maybe I should just keep factory speakers since it has built in tweeters. Just a 2000 Pontiac Grand Am SE.
Sorry for all the questions. Thx
And these:
