BadNewsBears
I have two speakers rated at 110 RMS@4omhs, I want them to run off the front RCA out, so how big of an amp do I need. A one channel 200 watter? or????
Originally posted by: edro13
2 speakers = 2 channels... (Unless you are using subwoofers, you can use a single channel and run them in series...)
If you only want to power your front 2 speakers, get a 200W, 2 channel amp. But I recommend powering all 4 of your speakers. If your car is half way normal, it has 4 speakers in it plus your powered subwoofer. Get a 4 channel amp to run your 4 speakers...(buy 2 more speakers, they are cheap)
What kind of car?
No. You can run many number of speakers off a single channel.Originally posted by: Gerbil333
No! Two speakers = Two channels. Each speaker = 110W RMS, so you need two channels that produce 110W RMS each at 4ohms...
Got it, that was actually my second thought.Originally posted by: Gerbil333
WTF?Originally posted by: Munchies
ANY RECOMMENDATIONS!?
If you're running them both off the same channel you can use 1 amp to power the speakers, either wired in parallel or in series. If they're wired in parallel the resistance will be 2 ohms, in series it will be 8.
Sounded like you agreed with what he said, which was wrong.Originally posted by: Munchies
Uhh? Thats what im going to do. One 2 channel amp with the two infinity kappa's I have. All I need is a reccomendation of a good amp.
