Originally posted by: Z24
Hi,
The Kappa Perfect has a HUGE markup. I got mine with a friend's employee discount at about 1/2 retail price.
So, how does it compare as a $150US sub?
Shockwave,
I honestly don't remember the measurement on my box (been a few years since it was setup). I'm pretty sure it's 1.25 - 1.5 cu ft with some kind of stuffing in it (again, fuzzy on the details). Are you telling me that I'm far out of spec with this setup? What exactly am I hurting with this size box?
Boxes are like computers man, we all have our favorites
Is YOUR box out of spec? No, generally boxes dont have "spces" in regards to subwoofers. Now, what boxes DO have is affects on subwoofers! So no, your box is not out of spec. In fact, if YOU like the sound of it, your box is fine! An easy test is to remove the polyfill (That is the fuzzy stuff inside the box) Polyfill makes the speaker think it is in a bigger box then it really is, so in fact your speaker may THINK its in a larger box! Remove it, see how it sounds. You might not even hear a difference! SQ in speakers is VERY subjective, essentially what people who are really into this do is model a box for a particular speaker, see what it looks like, build it, listen to it, and then back to the drawing board. So, you may have 2 or 3 different boxes for the same speaker, just to see what happens. I would think with the polyfill it probably sounds pretty good. And for the price, I think your doin fairly well
