clamum
For those who know car audio, more specifically, amplifier settings (LPF and gain level):
What do you recommend I set the LPF at? I've read that 80Hz is a good starting point.
As where to put the gain level (it goes from min to max), I've read that you should put it at it's lowest position (min in this case) and turn up the volume on your HU to a bit higher than you would ever listen to it (for me that's pretty damn loud). Then slowly increase the gain level and when it starts distorting, crank it down a notch and you should be set. Playing any song during this process will work? I mean, should I get a bass heavy song to tune it to?
Thanks for any advice. 🙂
