Car Audio: Amplifier Bridging Question
FMJGomerPyle
246
I have a 4 channel amp that needs to power two subs. The amp has 8 speaker connections on it, each group of two labeled 1 2 3 and 4. It has two bridging buttons labeled "1/2 Bridge" and "3/4 Bridge" Once those buttons are pushed, where do I connect the positive and negative of each speaker?
Viperoni
11,084
It should say on the amp or in the amps manual.....it vary's for each amp, and I wouldn't recommend just touching the wires to find out either.
FMJGomerPyle
246
I don't have a manual and the diagram on the amp doesn't have anything about bridging. I would think this would be common among amplifiers.
glen
15,995
It will be the positive of one and the negative on the other.
I don't think you will hurt anythign by trying out both combos.
Viperoni
11,084
<< It will be the positive of one and the negative on the other.
My carver car amps the positives of both channels, see the difference.
It's different because there's different circuit layous and amp chips used in most amps....
I doubt you'll do any damage, but posting the model number and name of the amp would be helpful...
