F funkgab Member Dec 30, 2005 52 0 66 Apr 5, 2013 #1 Anyone do it here? Anyone know where i can get some mil-spec parts for it?
deadlyapp Diamond Member Apr 25, 2004 6,658 737 126 Apr 5, 2013 #2 Mil-spec parts? Do you know whats wrong with it? There are a lot of electronic components that can go bad and it's not the easiest thing to repair.
V Vdubchaos Lifer Nov 11, 2009 10,408 10 0 Apr 5, 2013 #3 I'm curious too. I have an amp that has issues with the power/ground connections (on/off sporadically).
F funkgab Member Dec 30, 2005 52 0 66 Apr 5, 2013 #4 buddy of mine bought it "repaired" like this as you can see it sits high, and it doesn't look like its the appropriate size (it's hitting the amp cover and my friend is worried)
