car amplifiers
Phillip
i've got an amp driving 2 6x9's at the moment
i want to add in another amp to drive a bass bin
can i just hook up the new amp using the same power supply wiring thats already installed for the 6x9 amp?
thx 🙂
Use a distribution block for both the ground and power. You can piggy back off of the remote wire and RCAs.
:thumbsup:
someone (somewhere else) mentioned crossover....
do i need to do this to the wire before it gets to the amp stage? or can i have the signal wire just forking off into each amp, and the amp's internal circuit take care of it?
