Here is my setup:
Pioneer GM-X702 amplifier.
Bandpass Subwoofer Box
2 - Orion XTR 4 ohm subs 12" subs.
The amp specs are below. The amp has 1 stereo input, and two speaker outputs. For right now I have each sub hooked up to each output. I know this is not good because you don't want stereo in a sub. The amp has a little picture of which terminals to use for mono. I tried wiring both subs up to the mono setting on the amp and that didn't work because the amp kept cutting out. How should I be hooking the speakers up? It's been a while since I had an electronics couse
Specs:
Bridgeable 2-Channel Power Amplifier Built-In Crossover Continuous Power: (20-20kHz, 0.04% THD): 2 ch: (4 Ohm) 75W x 2 2 ch: (2 Ohm) 100W x 2 1 ch: (4 Ohm) 200W x 1Maximum Power: 2 ch: (4 Ohm) 150W x 2 (EIAJ)1 ch: (4 Ohm) 400W x 1 (EIAJ)1/2/3 Channel CapabilityNo Current Limiting Signal-to-Noise Ratio: 105dB Frequency Response: 10-60,000Hz RCA Input Level: 500mV
Specs:
