Car Alarm question?
freemanteo
Viper 790xv & Clifford Matrix RS3, what is the Diff?
I want to know what is the difference between the 2? Which is better?
Thanks.
Andone know of good car alarm forums?
clifford =P
is the rs3 g4 standard? or g5 standard? if so get it with wireless immobilizer + self powered siren, and you're set
Thanks.
install each one...kick your car...and watch the differences!
you didn't say if it was g4 or g5 or not
taht makes ALL the difference
and off the top of my head, afaik viper circuits are usually open, clifford usually closed (or vice versa)
if they pop open your hood and disconnect the battery, viper = you're fuct, clifford = you're safe
